Square D panels question
Old 03-03-14, 02:46 PM
Z
Does Square D QO come in 24 slot panels? I cant seem to find reference to a 20/24 slot QO panel?
Also is homeline, which does come in 24, a quality panel?
Old 03-03-14, 03:46 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The Homeline is the cheaper line of Square D that has an aluminum bus instead of copper like the QO. It also does not have the Visi-trip flag.
What ampacity panel do you need? Do you need a main breaker?
Old 03-03-14, 06:36 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
You might find a 16-24 in a 125 amp QO panel, but I don't think they make a 20-24 panel.
PCboss is correct, it's an aluminum bus loadcenter built to be competitive in the residential market. It's OK, but it wouldn't be my first choice.
Old 03-07-14, 06:27 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Have you checked out the SQD website ?
Old 03-07-14, 12:05 PM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
I believe they make a 30 space panel which should work fine and give you expansion room.
Old 03-07-14, 06:25 PM
CasualJoe's Avatar
Yes, they do have a 30 circuit panel. They also have a 30 space 40 circuit panel (30-40).
