Launcher for a spinning whirly bird from a shaft
Old 03-05-14, 04:53 PM
I have this project for school and its deadline is before Summer starts and I want a head start on it and I'm also sort of clueless. The jist of it is that there will be a solid shaft which will be spinning via a motor and on top of it is a plastic fan/turbine which lifts off. Now I got the dimensions for the shaft and case and bearings all set but just need to find a way to launch the fan from the shaft. A physical approach can be used but I'm first trying electrical means.
Hope I'm clear enough and posting in the right place!
Old 03-05-14, 05:17 PM
F
IF you can attach a metal ring to the whirly bird you could use a repulsion coil but a mechanical means would be far, far easier.
Old 03-05-14, 05:53 PM
Rough Rooster's Avatar
Received 16 Upvotes on 12 Posts
Did Google search for 'toy flying spinner' and this was first article.
Hot Sell Plastic Pull Line Spinning Flying Disc Toy - Buy Pull Line Spinning Toy,Pull Line Toys,Plastic Flying Disc Product on Alibaba.com
Played with similar spinners when I was a young boy back in 1950's.
They either were pushed off spinning rod mechanically or self launched from lift generated.
RR
