one switch and three wall sconces junction box?
Old 03-08-14, 06:28 AM
R
I am installing three wall sconces and was wondering if I could bring power to the switch, then go up to a junction box, that has one 12/2 going to each fixture, rather than having two go to each one? If so, I assuming I join all the blacks together and all the whites in the junction box?
Thanks
Old 03-08-14, 06:39 AM
Tolyn Ironhand's Avatar
Received 790 Upvotes on 669 Posts
Welcome to the forums!
What you describe would work, however the junction box would be required to be permanently accessible. You could just run a switch leg from the switch box, to each light fixture box, if the switch box is big enough (cubic inches), or just daisy chain the fixture boxes like this:
Switch box------> light--------> light--------> light
Old 03-08-14, 07:55 AM
R
I wanted to wire it whatever way would prevent me from running two romex cables to the first two lights, however I will if I have to
Old 03-08-14, 08:28 AM
Received 3,633 Upvotes on 3,255 Posts
You can use a single cable from a junction box to each scone but like Tolyn mentioned.... the junction box would need to be installed where it was always accessible.
Old 03-08-14, 11:53 AM
Is there a reason you do not want multiple cables in the light boxes? Most cases it is easier to daisy chain lights.
Old 03-08-14, 12:03 PM
R
I thought it would be harder to daisy chain it, rather than just run one romex up to a central point, then add the power from the switch. All you guys think the daisy chain is easier?
Old 03-08-14, 12:34 PM
As long as the fixture boxes have enough cubic inch capacity (at least 14 CI), yes. Having a junction box is more work than it is worth.
