Reload this Page >
NM-8 feeding smoke detectors on hard-wired 15A circuit -- why?
Old 03-09-14, 08:28 AM
I'm looking to add a new smoke detector to my existing hard-wired circuit. The circuit is 15A and shared with some light fixtures. When inspecting the existing smoke detectors, I saw that they are fed with NM-8 cable.
Why would they have used such a heavy gauge? Any reason I can't just tie in with 14/3 and run to my new detector?
Old 03-09-14, 09:31 AM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
Is the "NM-8" the number you saw on the outside of the cable? Are you sure it is #8 cable/wire? It would be quite a bit larger, and in most cases, a black cable.
If it is #8 wire, you could connect the #14 to it if the breaker protecting that circuit was no larger than 15 amps. However, if the #8 runs to the panel, it might not be good practice as someone later in life could change it to a larger breaker and over fuse the #14 wire.
Old 03-09-14, 09:48 AM
Received 3,881 Upvotes on 3,478 Posts
Are you sure that's not NM-B. Maybe 14/3 w/G
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Are sure that the 8 isn't a B as in NM B Romex.
Old 03-09-14, 09:56 AM
Thanks everyone. It is definitely #8 (heavy black cable, more round than flat). I checked another detector box upstairs and there is #8 going in and #14 going out to some fixtures. Odd. But I will move ahead by tying my new detector in with 14/3.
Old 03-09-14, 10:13 AM
It would be just about impossible to get 8-3 cable into a 1/2" knock out..... or did they not use connectors.
Old 03-09-14, 11:10 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The normal labeling for a cable says "NM-B 14-2 w grd. Something certainly sounds unusual. It would be a pain to fit that in a box.
