3 to 2 Prong Adapter
Old 03-09-14, 02:55 PM
R
Question 3 to 2 Prong Adapter
Is it safe to plug a surge protector into the 3/2 prong adapter to protect my Sony Bravia Television?
Old 03-09-14, 03:26 PM
Tolyn Ironhand's Avatar
Received 881 Upvotes on 744 Posts
The TV should work with no issues, are you sure the TV has a grounded cord? Many newer TV I have seen do not.
The ground is only there for safety to carry current during a fault. It does not serve any purpose during normal operation.
If your TV does have a grounded cord I recommend exploring if your home has a metallic wiring method that can be used as a ground. The adapters you posted only work a intended if they are properly installed.
Old 03-09-14, 04:35 PM
F
What do you mean by safe? Without an earth ground connection most surge suppressors are useless.
