universal box fit?
universal box fit?
Are all 4" boxes universal? Meaning can I replace an octagon 4x1 1/2 with a 4x4 with no alteration to the conduits feeding it? Are the knockouts the same?
Depends on the box, but in most cases you can get ones with the KO's you need on each side.
That said, a 4"x4"x 1 1/2" box is larger then a octagon box, which I believe is only 3 1/2". You might need to shorten some conduit(s) if they connect opposite sides.
