Adding a Receptacle
Old 03-10-14, 05:54 AM
Adding a Receptacle
I ran 12/3 from 2 circuits in my breaker box out to two receptacles so that I could have two dedicated lines in my shed.
Now I would like to add a receptacle in my garage which is right next to the breaker box.
So I want to tap into one of those two circuits that I just described.
How can i do this while of course staying in code.
I do not have any spots to add an additional breaker so if I cannot tie into one of these circuits then I guess the only other option is to replace an existing circuit with a tandem breaker?
Old 03-10-14, 06:49 AM
ray2047's Avatar
Do you mean you ran one 12-3 cable on two handle tied 120 volt circuit breakers on opposite legs of the 240v in your breaker box or do you mean you ran 12-3 from a 240v breaker to your garage or something else. Maybe two 12-2 cables to an attached garage?
12-3 is three conductors plus ground.
Old 03-10-14, 12:51 PM
pcboss's Avatar
Run a cable from the panel. Splice to the conductors for the shed. Add GFI protection for new receptacles.
