sub panel feed question
Old 03-10-14, 05:12 PM
R
We have a 200amp main entry panel, outside and downstairs. It also feeds a few yard circuits, and a 100 amp sub panel.
Is the sub panel fed by a four wire setup? Neutral, ground, and two hots for 120v/240v service? If this is correct, then I assume the hots are 2 gauge wires.
Old 03-10-14, 05:32 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
It should be.
That would be correct.
They might be. The size of the wires would be dependent on the size of the breaker feeding them, whether they are copper or aluminum and the overall length of the feeder.
