well pump wall switch
Old 03-14-14, 09:15 AM
I wish to install a wall switch that will cut my submersible pump`s power .As it is now the 240v comes from the breaker panel to a jncbx in laundryroom with red white and blk. and to the pressure switch with just wht and blk,all with no issues.
The panel is far from the laundry room so I want to install a wall switch close to the actual plumbing area. Is there any way this can be done? perhaps interrupting the blk& wht going to the pressure switch?
Old 03-14-14, 09:46 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
As it is now the 240v comes from the breaker panel to a jncbx in laundryroom with red white and black
That junction box would be a good place to interrupt it. Just replace the junction box with an unfused AC disconnect. Why a white from the panel on a 240 volt supply? Is the pressure switch 120 volts.
Old 03-14-14, 10:16 AM
Tolyn Ironhand's Avatar
Received 252 Votes on 220 Posts
You could also install a mud ring on the J-box and install a simple two pole switch. The switch would need to be rated to carry the load, so if the circuit is 20 amps, you should use a 20 amp rated switch.
Old 03-14-14, 12:28 PM
it looks like the ps could be either or , both are listed as option. so if I interrupt the blk wire leaving pressure switch it would stop the pump?
Old 03-14-14, 12:34 PM
what would be the best wire to switch with the mud ring 2 pole set up?
Old 03-14-14, 12:36 PM
If you break one line, it would stop the pump. However it sounds like you have no disconnect by the pump switch which is why both Ray and I suggest two pole disconnects, and interrupt both lines before going to the pressure switch.
Old 03-14-14, 01:40 PM
ray2047's Avatar
Wouldn't a toggle switch have to be horse power rated so you can't go by just the tungsten rating in amps.
Old 03-14-14, 01:56 PM
All I can say is that is done in my area all the time. 20 amp double pole commercial switches I have used are motor load rated. Not sure of the HP.
Example: Leviton 20 Amp Commercial Double-Pole Toggle Switch - White-R52-0CSB2-2WS at The Home Depot
Old 03-14-14, 02:05 PM
ray2047's Avatar
Probably just a nit-pick on my part since it will probably be seldom used. Thanks for the info.
Old 03-14-14, 02:14 PM
No, no. It is a good point. Really, when you compare the cost between an unfused disconnect, and the price of a double pole switch/mud ring/plate it would likely be close.
Old 03-14-14, 04:26 PM
thank you guys ,you`ve been a lot of help
