GFCI needed
GFCI needed
Can anyone tell me if a GFCI is needed in this pict
[ATTACH=CONFIG]28480[/ATTACH]
GFI protection is only required within 6' of a laundry tub. You do not need it unless there is also a tub in the room outside of your picture.
I believe I read somewhere that the 2014 NEC is going to require GFCI protection on all washer receptacles, but I have no reference for that. For most of us, what we now have would be grandfathered except some local jurisdictions may require it right away.
Sorry for the partial hijack, but why would "finished vs. unfinished" basement make a difference in whether or not a GFCI is required?
(I'm not challenging the idea, just looking for the reasoning in the code, so I can learn!!)
GFI protection is required by the electrical code for unfinished basements. If the basement is finished it is not required.
Furd
As a clarification, a "finished" basement has some kind of floor covering over the concrete, an "unfinished" basement has just the concrete (or dirt) floor.
So an insulated basement with Gyprock walls tops to bottom, but a painted concrete floor is considered unfinished for NEC wiring purposes?
Doesn't meet the common popular understanding of "finished", though.
