3PST Emergency Switch 20A
Old 03-19-14, 05:54 AM
N
Hello everyone,
I was trying to find a 3PST emergency switch with 20A DC contacts. Do you have any idea where to look? Google was not really helpful in this case (I onyl found 5-10A contacts).
Thanks for the help
Old 03-19-14, 07:54 AM
Received 3,980 Upvotes on 3,572 Posts
Welcome to the forums.
A 3 pole switch that handles 20A should be no problem to find.
What constitutes an emergency switch...... pushbutton, toggle, etc. ?
Do you want the switch contacts normally open or normally closed ?
Google didn't help much as your use is not clearly defined.
Old 03-19-14, 10:03 AM
N
Mushroom pushbutton switch, 3 NC contacts. I tried specifying these parameters in the search engine, but without success.
Old 03-19-14, 10:21 PM
The mushroom PB's are usually set up to control a relay or contactor.
I found the switch in a 10A model. Waiting for confirmation on a 15A model but nothing larger found. You didn't specify what DC voltage either.
Old 03-20-14, 01:01 PM
N
I will just use a relay then. Finding a switch is no problem then.
Thanks
Old 03-20-14, 02:22 PM
Ok.... if you need further help.... ask away.
Old 03-21-14, 11:30 AM
P
Consider a 3-pole, 20 amp , circuit-breaker.
