ireversible connection on ground?
Old 03-21-14, 02:55 PM
C
Code calls for GEC to only have splice if its a irreversible connection or a weld.
What are the irreversible connectors?
And is that reasoning so that the ground doesn't get inadvertently disconnected or is it because a standard connector would be no match for a lightning strike?
Old 03-21-14, 03:40 PM
pcboss's Avatar
Received 192 Upvotes on 168 Posts
Irreversible connections are hydraulically spliced under pressure or a thermal weld process like Cadweld.
I am not sure of the reasons.
Old 03-21-14, 03:43 PM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
Crimp connecters are irreversible. Your AHJ would know what is acceptable in your area.
The reason is to avoid a splice that can loosen over time.
