strands of stranded wire
Old 03-22-14, 01:09 PM
bigboypete's Avatar
I had a hvac installer put in an AC last year. I had to remake the connections in a junction box with the supply wires.
I noticed a stranded #10 joined with a solid #10. The stranded conductor was damaged, it had perhaps half or 3/4 less strands showing in the splice. So it was more like a #14 stranded joined with the solid. Yet there was no sign of overheating.
Was that joint destined for failure? The fool who made the splice should be docked.
Old 03-22-14, 06:30 PM
CasualJoe's Avatar
Received 187 Upvotes on 168 Posts
Maybe.......Where was the connection and who installed it and/or made the connection?
Old 03-23-14, 06:56 PM
Z
Received 425 Upvotes on 378 Posts
It's definitely not a properly made splice with that many strands broken off.
How much of an overheating issue it was really depends on the actual load, and how secure the connection actually was. I would definitely redo it, if you haven't already.
