How to get latex paint off wires
Received 0 Votes
I had painted my air conditioner wire the last time I painted.What is the best way to get that coat of paint off.
Products like 'goof off' and 'oops' will dissolve latex paint allowing you to remove it. I don't think it will harm the wires but don't know for sure.
I'll move your thread to the electrical section so you can get their take on it.
Received 0 Votes
Sand it and repaint it lol. You'll be sitting there all day today and tomorrow trying to get the paint off. Then, when you're 1/4 of the way done, you'll be about ready to strangle yourself with the cord.
Received 0 Votes
Yes a through the wall unit. Yes many people paint the power cords (blends into wall much better,does not stand out so much) and just keep on putting more paint on top of the old paint. I did not want to keep on putting a few layers of paint on the power cord. Was just wondering easiest way to remove latex paint.
As written earlier try Goof off. I'd advise against try to sand the cord. You may damage it. Of course the goof off may damage the cord even more then sanding. Best might be to get a new cord and stop painting it. How far from the A/C id the receptacle for the cord? Moving it closer so if it isn't within a foot or so and concealing behind curtains might be a better solution.
I'd disagree.
Received 0 Votes
Allow me to share some beneficial and relevant information and experience...
Goof off is a very mild solvent. It also evaporates extremely quickly. It's best used to clean up 'spills', like paint on carpet or maybe a drop on your clothing. I have used goof off to clean dried paint off the interior of my car: plastic, vinyl, cloth. It works, but it takes a fair amount of elbow grease.
Can it damage your power cord? Yes, if you leave it submerged for a prolonged period of time. Will it damage the cord if you apply the goof off to a rag then wipe the paint? No. Will it remove the paint? Yes, but extremely slowly and not without lots of hard work.
Varsol, an actual paint thinner, might work better. Thinner, not stripper, those would be too harsh. Use varsol on a rag and wipe the paint. Again, I have used it in my car to clean paint with no damage to the trim, seats, or steering wheel. It will still take plenty of effort, but not as long as goof off.
Will it damage the cord? Yes, sooner than the goof off, but again only if then cord is wet for a day or two non-stop.
Soure: I'm a professional painter and use these solvents on a regular basis.
Use Goof Off 2.
Goof Off I've found ruins the finish of alot of things. Goof Off 2 uses the power of citrus!
I've used it to clean off the paint some kids sprayed on my trunk and tail lights. Got every drop off and didn't damage my clear coat. Not much effort needed with this stuff either.
