Gfci
Old 03-29-14, 06:51 AM
R
Gfci
I have voltage at the terminals of the outlet. I have voltage when I test with meter across the black wire and ground AND black wire and white wire. I still have no voltage in plug itself. Replaced outlet with brand new one same thing. The light on GFCI is yellow instead of green. I have reset both repeatedly.
Old 03-29-14, 06:54 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
What does the instructions say the yellow light means? You may have the receptacle mis-wired.
Old 03-29-14, 07:07 AM
Tolyn Ironhand's Avatar
Received 878 Upvotes on 741 Posts
Make sure you have the wires to the LINE terminals and not the LOAD terminals.
Old 03-29-14, 07:28 AM
R
Thanks guys. I bought a multi pack of Gfis and can't find the instructs. I'll check the line/load inputs. Duh!
