How to use grounding wirenut?
Old 03-29-14, 12:16 PM
C
How do you use a green wirenut with the pigtail hole in the top? You wouldn't be pretwisting the wires obiviously.....
Old 03-29-14, 12:32 PM
F
You leave one bare grounding conductor long and then cut the rest fairly short although still long enough to extend outside the box. Thread the wire nut on the long wire and then match up the rest and screw down the wire nut. And yes, you could pre-twist all of the wires if you so desired.
Old 03-29-14, 12:41 PM
C
im having a hard time picturing pretwisting the bundle of wires with one 8 inches longer than the rest.....
So then the pigtail is attached to the box?
Old 03-29-14, 12:53 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
You can wrap the ground screw with one of the conductors before the splice. The end out of the wirenut goes to the device.
Old 03-29-14, 12:58 PM
F
So don't worry about pre-twisting, it isn't necessary anyway. If you have a metal box then yes, connect the tail to the box. If you have a plastic box then connect the tail to the device's grounding screw.
Old 03-29-14, 01:15 PM
pcboss's Avatar
Here is one picture, although the part out of the cap is too short.
Greenie® Grounding Connector
Old 03-29-14, 01:36 PM
ray2047's Avatar
Here is a more accurate view:
Old 03-29-14, 06:57 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Why not? Just a couple twists with lineman pliers and cut off all the tails except for the longest one, then apply the Greenie.
Old 03-31-14, 11:03 AM
C
Finally wrapped my mind around it with some scrap wire and a green wirenut. I don't see any application in my house where I will ever use them though!!! Thanks!@
Old 03-31-14, 12:27 PM
ray2047's Avatar
What you never intend to ever install any lights or receptacles that have more than one cable in the box?
Old 03-31-14, 07:28 PM
CasualJoe's Avatar
You do not have to use the Greenies with the hole in the end, you can still simply pigtail your grounds and secure the twisted splice with a normal type wire nut. Regardless of which type you use, a wire nut is required for splicing the grounds together.
