Metal boxes in wall
Metal boxes in wall
I'm looking at a condo built in 1990 and was trying to figure out a little more how it was built. This is a "ground floor" unit which is basically a daylight basement as it is built in to the hillside. Only one side has windows; this side is all at/above grade. The unit sits on top of an all-concrete parking garage which is mostly underground. A couple parts have linoleum which feels really solid so I'm assuming this unit is built on a concrete slab (the roof of the garage).
I popped off one of the outlet plate covers on a common wall to see what was inside the wall. It was hard to tell, but it looks like the outlet was mounted in a 2 gang metal box with a 1 gang adapter, such as the following:
[ATTACH=CONFIG]29262[/ATTACH] [ATTACH=CONFIG]29263[/ATTACH]
It was definitely a metal box inside. Much roomier than the standard 1 gang boxes. The drywall cutout was about the same as what you'd have for a plastic ox. Normally I'm used to seeing plastic 1 gang boxes nailed to a stud. I've never seen this before and am just curious as to what is going on here and what advantages there are to using metal boxes.
A normal construction technique is to have a masonry wall between two units. The inside walls are furred out with metal studs or 2x furring strips. This allows the interior finish to be installed without loosing too much floor space. Standard plastic boxes are too deep for these walls so the metal boxes are used with plaster rings. Same amount of space just not as deep.
