Question on Digital Multitester Reads
Old 04-03-14, 04:11 PM
B
Installing a ceiling fan/light and replacing light wall switch. Digital multitester readings on wires at switch box:
Hot/Ground - 120ac, as expected
Ground/Neutral ~10ac, ????
Is there an ok explanation for the Ground/Neutral read, or what should I do?
Thanks for help.
Old 04-03-14, 04:15 PM
pcboss's Avatar
Received 201 Upvotes on 176 Posts
This is phantom voltage and would go away under load.
Old 04-03-14, 04:17 PM
ray2047's Avatar
A cheap analog or expensive brand name digital multimeter would probably show closer to zero.
Old 04-03-14, 04:23 PM
B
Thank you pcboss and ray2047 for quick reply. Very helpful.
