how to wiring single Pole Switch and 3 way switch on the Same Circuit
Received 0 Votes
Hello everyone.
Currently a have a circuit (15amp) working with one single pole switch and 3 lights. The power coming from the panel to the switch.
And now I would like to add on the same circuit 6 recessed lights with a 3 way switch.
That is possible?? How can I do that? Any diagrams ? or where I can find more information?
Thanks in advanced,
Thanks in advanced,
While they make combo SPST/SPDT switches for a single gang box since you need to pull the box anyway to fish new cable I'd just go back with a two gang old work box and separate switches at the existing switch location. You will need to a 3 conductor cable to the second new switch location and a 2-conductor cable from that location to the first can light. The remaining can lights will be daisy chained from the first can light.
Received 0 Votes
Thanks ray2047 for help me.
So To connect the remaining can lights can I use 14/2 from the second switch to the 1 light.
From L1 to L2 #14/2
From L2 to L3 #14/2
From L3 to L4 #14/2
From L4 to L5 #14/2
From L5 to L6 #14/2 and here will be the end of the circuit
That is correct?
Can I replace the second switch for a dimmer?
The circuit will be the same or it will change?
Thanks
From L1 to L2 #14/2
From L2 to L3 #14/2
From L3 to L4 #14/2
From L4 to L5 #14/2
That is correct?
Thanks
If it is a 15 amp circuit you can use #14. 3-way dimmer switches depending on type may need a slave and master but some will work with a regular 3-way switch and a dimmer on the other end.
