Seperate Bath Light/Fan switch into 2 separate switches
Received 0 Votes
Hi,
I know this has been asked multiple times but I can't seem work out how to do this for my set up and whether it is possible.
I have a switch operating the bath fan and light and wish to separate them into 2 switches. Below is how it is currently wired. Is it possible? I am not sure as there are only 2 cables coming in.
The B/R/W numbers are just to help in answering where I would connect them.
Thanks!
Thanks!
Assuming that the unswitched power from the panel comes in on cable 2 and that the switched power goes to the fan/light combo through cable 1, make a pigtail to connect both switches to B5. Connect B2 to one of the switches and R2 to the other. You should only have one splice - for the neutrals - when finished.
Received 0 Votes
Thanks for the quick response.
You mentioned Cable 2 twice, I assume you meant Cable 1 goes to the fan/light combo not Cable 2?
I checked the cables with detector and Cable 2 is HOT with the switches off as shown so must go to the panel.
So to confirm is this what the wiring should look like?
Received 0 Votes
Worked perfect - thanks again!
I didn't realize twin switches came with a single common so I didn't need a wire nut to tie B5,B7,B9 - I just wired B5 straight into the twin switch.
