12 gauge extension cord with in-line switch? or custom made?
Received 0 Votes
Hi all,
Note: I rent a house so I can not change the actual outlets to install a wall mounted switch. I can't change much about the house.
I charge up my electric car at night via a 12 gauge 25 foot extension cord. I usually charge up at 120V @ 8AMPS but sometimes I charge up at 120V @ 12AMPS. I'd like to limit the amount of time the cord is "hot" & I'd like to avoid constantly unplugging the cord. The reason I do not wish to keep the cord "hot" 24/7 is because we have kids around the house (the chord is mostly high above where they can not reach it..but at one point it comes within reach as the cord goes out the unused mailbox) so I want to reduce potential accidents if they cut the cord & also the cord goes outside the house so I don't want a "hot" cord outside where the kids play.
So I was wondering if anyone knows about a 12 gauge extension cord with a built in in-line switch or if it is safe to add an in-line switch to an existing extension cord using components which can handle 15AMP or more. If this is a DUI I'd probably hire a local electrician since I'm already working multiple job and don't have time for a hobby project right now
Thanks for suggestions and tips.
You could also use a plug in timer like this which it will only be on the times you choose automatically:
Amazon.com: GE 15153 Heavy Duty 24-Hour Mechanical Timer: Home Improvement
Or you could do a countdown timer like this which you set to run for a set length of time. So if your car takes 8 hours to charge, you set it to 8 hours and it will shut off after the set time expires.
Amazon.com: Woods 50030 Indoor Countdown Timer, 1-Outlet Grounded: Home Improvement
These are only examples and you can buy them in many stores.
I would make sure the extension cord is being plugged into a GFI receptacle or short GFI cord. This will help protect from most accidents involving the cord.
Here's a 15A grounded switch that may work
Belkin F7C016q Conserve Power Switch - Smarthome
Two birds....GFCI protection and test switch built in to disable it. Defiant, 2 ft. In-Line GFCI Cord, 30338213 at The Home Depot - Tablet
Received 0 Votes
I like the Belkin switch. The outlet is GFCI. So if I went the route of the Belkin switch here is the setup: 120V GFCI outlet->Belkin switch->12 guage extension cord 25ft->car's EVSE (electric vehicle supply equipment..has GFCI in it too)-> car (Chevy Volt)
