Grounding a double gang box
Old 04-06-14, 08:07 AM
T
When using a double gang receptacle box where both outlets in the box are directly connected to each other, can I ground to just one of the outlets? This is in a conduit/metal box configuration.
Old 04-06-14, 08:54 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Do you have a separate ground run, or is the conduit metallic and used as a ground? Using self grounding receptacles will allow for a continuous ground in a metal box, but if you have a separate ground, it must be screwed to the box via a grounding screw. Need to know the complete set up.
Old 04-06-14, 08:57 AM
T
The conduit and box are both metal
Old 04-06-14, 09:48 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Both receptacles need to be grounded to the box by pigtails unless they are self-grounding.
Old 04-06-14, 02:44 PM
Nashkat1's Avatar
Received 2 Votes on 2 Posts
both outlets in the box are directly connected to each other,... The conduit and box are both metal.
It sounds like you have a ground wire. If so, that wire needs to be connected to your metal box with a green hex-headed ground screw. And,
