Adding outdoor outlet to covered patio ceiling. Special NEC reqs?
Received 0 Votes
Adding and patio outlet to my covered patio celing for a TV.
Just curious if anyone knows of any special NEC code requirements besides using a weatherproof box and weather resistant GFCI receptacle?
Welcome to the forums!
Weather resistant wiring. You may need an in-use cover on the receptacle, depending on where it's located. That would probably be easier to use with something that's always plugged in, anyway.
Two questions: Where and how are you planning to pick up the power? How is the ceiling constructed?
Received 0 Votes
This is the box/cover combo I plan on using
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
The ceiling is made of wood. I do have attic access to the ceiling. There is a power outlet in the attic in an new work box nailed to stud that's close by that I plan to use for the power source (got lucky there).
About weather resistant wiring. The house is fairly new, 2007. The builder ran 12/2 romex to the recessed lightning on the patio. Will that suffice?
Are there rules about how far away the outlet has to be from the exterior walls of the house ( i.e. could I have it tucked in the corner)?
Are there rules about how far away the outlet has to be from the exterior walls of the house (i.e. could I have it tucked in the corner)?
Yeah the box seems great because I can paint it to match the ceiling.
Good box, though. I'm coming to appreciate Arlington Industries more every day.
