Reload this Page >
Need Help Regarding Butt Welder...Input Connection HELP Needed
Old 04-12-14, 09:17 AM
Hello Friends...
I Recently Get A Butt Welder From China....Unfortunately The Manual And All The Instructions Are In Chinese....Its Easy To Operate So No Issue Of That
Problem Arise When I Unbox It And Found Only 2 Input Wires ...On Top STicker Says 380v
We Have 220v(Line To Neutral) Voltages Here And I Have 3 Phase Connection Available....
When I Purchase .....I Know That Its 380v Means 3 Phase ..Will NOT Work On Single Phase....So I Get 3 Phase COnnection...
I Am Confused What It Means And Why It Have Only 2 Wires For Input...Not 3
As I Installed And Know....380v Motors And Appliances Require 3 Phase Input And Thats It......
It Have Only 2 Wires And Below Is Bolt With Ground Symbol........Means Connect Ground...
I Am COnfused How To Connect It....
It Either Need 2 Phases Only Not 3 Or Its Something Else????
Attaching A Circuit Diagram What Comes With Manual
Any Help Would Be Highly Appreciated
Regards
F.K
Old 04-12-14, 09:20 AM
Forget To MEntion....It Is Used To Weld Bandsaw Blades
Old 04-12-14, 10:48 AM
ray2047's Avatar
Two wires indicate single phase. You can get 380 from 3 phase wye phase to phase.
Old 04-12-14, 11:01 AM
You Mean To Say We Need Single Phase 380v(Line To Neutral) ??
In China Its Same 220v Single Phase Or 380 3 Phase......I Wonder How They Make Something Which Need 380v Single Phase
Old 04-12-14, 11:28 AM
ray2047's Avatar
No, sorry for the confusion. If you have 3 phase wye you should have 380 phase to phase. You would need two wires. Verify the wires are 380.
Old 04-12-14, 11:32 AM
This Is What I Was Wondering...
I Guess I Need To Feed Two Diff Phases To Each Wire......Making 380v....??Correct
Like I Have L1 , L2 , L3 And N(4 Wires From Power Meter To Power Box)......I Will Have To Use L1 And L2......
No Neutral Is Involved......
I Think I Got It Correct?????
Old 04-12-14, 11:35 AM
ray2047's Avatar
Yes, that is correct just be sure to verify the voltage Yes, no neutral.
Old 04-12-14, 11:37 AM
Thanks For The Reply Bro.....
Will Verify The Line To Line Voltage But As A Rule Of Thumb Say
Its 380v For 220v(Line To Neutral) ....I Just Have To Use Two Diff Phases...Which I Have....!
