Possible dispute with electrician over final bill
Hello All,
Sorry for the long post but I could use some advice here. I would like to get a second opinion of an issue we are having with our electrician. We just finished the remodel and received our final electrical bill (via the GC). The bill seems to be pretty far off. My contractor feels I am being gouged as well.
The main "change-order" item is the addition of the sub panel. Due to not having enough room in the existing 150A panel, a sub panel needed to be added alongside. For adding this panel he is billing $1000. However, only the panel is being added as all breakers/wiring were covered under the original design (which I paid already). Are there other costs I am not seeing besides the actual panel box?
Then there are other miscellaneous items: add-on recessed cans at $200 each (added to existing string) and added outlets at $125 each (added to existing string).
I would like to pay what is fair but I don't want to be gouged. There are no signed change orders.
Thanks
Thanks
If this electrician didn't have you sign a change work order nor worked out an agreement with you for time and material then I think that is bad etiquette just to slap you with a 1000+ addition and expect to get paid without some resistance. That's what these contractors do, its a racket.
Received 38 Upvotes
The prices for the recessed lighting and the extra receptacles may be reasonable depending on the labor involved. What I don't understand is how the additional circuit breakers could be part of the original cost and yet later a sub-panel be required unless the original job was bid without ever looking at the site. If the service panel didn't have room for the new CBs then that would have been immediately evident in the original plan and the sub-panel would have been included in that original bid.
Utterly impossible to state with any finality. Since we do not know the size nor manufacturer of the sub-panel any guesstimate of the cost is nothing more than that, a guess. If the wall where the sub was installed was a finished wall the labor costs of installation could be high. Still, $1,000 DOES sound high without knowing the full story.
Material cost is less than 50 bucks.
Last I checked contractors were not allowed to ambush you with an extra bill in excess of the original written contract without your signing off. If you had a written quote (not an 'estimate', whether written or verbal - estimates are non-binding) and that's what you paid before the work started, that is a contract.
As far as the 'miscellaneous items', if the electrician installed those extra light cans and outlets without your permission/acknowledgment when they were not on the original quote/contract, then it's not your responsibility.
What he is doing is tantamount to extortion. Florida is pretty aggressive toward bad contractors, due to the large senior population. If he doesn't back off, contact the Florida Attorney General's office and the Department of Business and Professional Regulation (that's the department that issues his license), and file a complaint
As eluded to above the bill you are looking at is probably not what the electrician gets, being a sub. Thus some of that money may be going into the GC's pockets. If you started with a signed contract specifying certain work and did not sign for the additional work then you should have some leverage to at least trim this down to what you can be comfortable with. That or they do some explaining as to exactly why those amounts are justified.
Start a paper trail by making requests in writing and keep notes as to their response. Don't threaten the AG until you have to as that can shift the conflict to a different level. Was there any language in the original contract for dispute resolution? Are there any other electrical related issues that need to be brought to the table now, as later they may not be addressed? Has a mechanics lean been filed (you should have received a notice). Did they pull an electrical permit? Was all work inspected and approved?
Bud
Bud
See the GC and electrician are pals. Its a racket. You can bet they are laughing at you together while enjoying cocktails and crunching the numbers at the local pub at lunchtime.
So when you don't pay what will you do when these scumbags threaten to put a lein on your property?
$200 for the recessed cans and $125 for receptacles seem within the realm of reasonable to me. It's in line with an electrician my parents used a number of years ago.
Installing a subpanel should have taken an hour, maybe 2, plus materials.
But as others have alluded to, we can't really help you much. "Some guys on the internet said..."
Your first line of defense is the GC. He should (in theory) be looking out for you and should be willing to talk with the electrician.
Keep notes of your discussions with the GC and electrician. If you find you're not getting anywhere, find a local lawyer. Many will help with an initial consult for an hour's worth of $$, and just letting the GC and eletrician know that you have a lawyer who said ..., might get them to change their tone - especially if there's no documentation for these upgrades.
Good luck!
Good luck!
