low voltage lights for retaining wall and pavers
Old 04-18-14, 06:31 AM
Can anyone recommend a product/brand for simple low voltage (LED?) lights that can be put into a retaining wall?
I have two retaining walls on a driveway. I want to put maybe 3 lights on each side just to get some vision at night.
I also have a path of pavers leading to the house. I was thinking of replacing 3 pavers on each side with low voltage lights that are the same dimensions as a paver.
I see a lot online but I don't know the quality. I want something that can last through NY winters.
Old 04-18-14, 10:22 AM
Received 3,897 Upvotes on 3,494 Posts
I would highly recommend using LED type lights from a major company like Stonco or RAB.
I don't see a lot from the big guys that would be helpful here.
Lots of different types available. It's the quality and durability that is the question.
Gro▀handel Boden
Old 04-21-14, 11:25 AM
Didn't find anything for stonco. RAB has one but I'm not sure I like it. Any other suggestions?
I found the following:
http://www.amazon.com/WAC-Lighting-W...WL-LED100-C-BZ
Anyone know if WAC is any good? That doesn't look like it will stand the outside weather.
Old 04-21-14, 11:37 AM
Received 1 Upvote on 1 Post
For over a hundred bucks a pop it BETTER stand up to the weather!
