Door Chime
Old 04-21-14, 03:29 PM
L
Door Chime
Separated from: http://www.doityourself.com/forum/el...ell-chime.html
i would appreciate if you could tell me where you purchased or the name of your door chime. I am trying to replace one (circa 1960's) that fits in a 3 x 2 electric box. Thanks
Old 04-21-14, 03:40 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The chimes are normally much larger than 2x3. Are you asking about the transformer on top of that box?
Old 04-21-14, 04:40 PM
L
it is the actual doorbell
Old 04-21-14, 04:50 PM
ray2047's Avatar
Some short lived product is my guess. You won't find a replacement. Since you failed to fill out the critical information in your profile giving your location I can only guess not U.S. Certainly not like any chime I have seen. Only a buzzer would be small enough to fit.
Old 04-21-14, 04:57 PM
L
Thanks for your help - location is Rhode Island. It is original to the house which was built in 1960/1961.
Old 04-21-14, 04:59 PM
ray2047's Avatar
You aren't likely to find a replacement. What is the transformer voltage?
Old 04-21-14, 05:19 PM
L
Sorry I have not been able to figure that out. I don't like the idea of going with a wireless but sometimes the path of least resistance is the best.
Old 04-21-14, 05:47 PM
A
Received 92 Upvotes on 84 Posts
Looks like Edwards 660 Ringcall
Sears.com
Old 04-21-14, 05:59 PM
L
THANK YOU!!!!! This stumped several electrical supply houses and several of my local hardware stores. Thanks for sharing your knowledge.
Old 04-21-14, 06:08 PM
A
I've seen them mostly in apartment buildings with a light switch cover on the front of it - it does look kind of odd. Since this is a standard low voltage chime you could buy almost any normal wired chime and mount it in front of the hole in the wall. To me it would look a lot better and add some character.
Old 04-21-14, 06:10 PM
ray2047's Avatar
Good find but it means you haven't found your door chime. Are you sure there is a door chime? is there a door button?
