Having trouble with devices installed on vehicle !
Old 04-22-14, 01:11 AM
A
Unhappy Having trouble with devices installed on vehicle !
Hello,
I am having some serious trouble with the devices placed in a vehicle, I am trying to add devices to it and get them powered during the start of the vehicle.
Electricity Source: DC 12V { Battery }
CONVERTER - [ DC -> AC ] 12V
ADOPTER - 12V AC -> 6V AC
Devices Power requirement->
5V AC + 1.2 Amp [Device 1]
WIFI Dongle dont know the power requirements it also requires 5V AC
Graph is also added
The devices circuits are failing due to fluctuating current from the battery, thus the reading of electricity is also different, can you help me achieve this, without increasing the price significantly !
Thanks in advance.....
- Arjch
Old 04-22-14, 04:22 AM
ray2047's Avatar
Simplest might be a second battery with an isolator. Vehicle starter draws more than 100 amps for a few seconds lowering voltage.
Old 04-22-14, 04:24 AM
R
Received 1 Upvote on 1 Post
Are you sure these devices require 5 volts AC?
You said you want to power the devices "during the start of the vehicle." The only way to insure constant power to your devices is to use a second battery that is isolated from the starting battery, but uses the car's electrical circuit to charge both batteries.
A device called a "battery isolator" will do the trick. It also prevents the starting battery from being drained by the devices.
