Replacing 220v 20 amp receptacle outlet
Old 04-25-14, 12:56 PM
R
I have a dedicated outlet for air conditioner in my apartment that has a 6-20R outlet ,220v 20amp, but it seems none of the a 220v air coditioners they sell use this outlet. They seem to use 6-20p outlets which is the mirror image of the 6-20r. Would I able to just purchase an outlet which is 6-20p and replace the 6-20r myself or would it not work Sorry for my electrical ignorance. Or is there an adapter they sell that goes from 6-20r to 6-20p, I cant seem to find one online, that would seem the easier choice.
Old 04-25-14, 01:02 PM
ray2047's Avatar
You either mis typed or are misunderstanding the designation. The P in 6-20P means Plug and it goes in a 6-20 R with R meaning receptacle so they are the two parts of one connector.
But you said apartment and if you rent you shouldn't touch the wiring. Call the landlord
Received 78 Upvotes on 73 Posts
What you have in the wall is a 6-20R R=Receptacle the A/C has a 6-20P P=Plug
The two are compatible one is the Female (The Receptacle) and the other is the male (The Plug)
Old 04-25-14, 03:39 PM
R
6-15p plug into 6-20r receptacle
Mod Note: This post merged with your original thread.
I am looking to purchase an air conditioner which uses a 6-15 plug which looks like this
O
- - 6-15p
the outlet in my wall looks like this
0
- l-
Will the plug fit into the wall outlet and is it safe to do so? I know the air conditioner uses a 6-15p and from the configuation of my wall outlet it looks like a 6-20r
Old 04-25-14, 04:15 PM
Received 3,991 Upvotes on 3,582 Posts
A 6-15 Plug will fit into a 6-20 Receptacle.
The only difference is the 6-15 is rated at 15A and the 6-20 is rated at 20A.
There shouldn't be a problem with the air conditioner.
If you wanted to be 100% politically correct..... you could replace the 2P20 breaker with a 2P15 one.
Old 04-25-14, 04:24 PM
ray2047's Avatar
Since you are a renter the landlord would have to change the breaker but you really don't need to.
Old 04-25-14, 04:31 PM
Ahhhhh......didn't realize the OP was a renter.
As Ray said.... the 20A breaker is fine in your application.
Old 04-25-14, 05:01 PM
R
Thank you so much for all your replies! Fell much better purchasing a 220v air conditioner using a dedicated circuit as my old 115 v used to blow the circuit sometimes when I turned it on.
