Electrical Circuit
Received 0 Votes
Electrical Circuit
When renovating my existing bathroom, there was no electrical work required. We had power at the source and all the plugs and lights were working. When changing the GFI plug the outlet popped. My brother-in-law hit the reset button and we have absolutely NO power anywhere in the room at all. We checked the main breaker and it was fine. As a matter of fact, there is a plug inline from the breaker to my bathroom and it still has power. We have taken all electrical devices out of the room and have completed a continuity test so I believe I have isolated what 'should' be my hot source but nothing. Can anyone out there help me understand what may have happened and what I may want to try to fix this problem???
Welcome to the forums! Is the circuit already fed from an existing GFCI in another bathroom, crawlspace, garage, or other location? Of course I'm going to have to ask you why you left the circuit live to replace the receptacle
If there was no electrical work required.... why was the GFI receptacle replaced ?
If everything was working before the GFI was replaced.... that's where I'd check for live power.
Received 0 Votes
Thanks guys for all the help. I have no idea why my brother-in-law kept the power live. The problem was back on the only other plug in the circuit and when this was inspected we changed the wiring (swapped the black and the white wires) and everything now is fine??????
Thanks for the tips guys, greatly appreciated.
Hopefully you didn't just randomly switch the black and white wires.
The black and white wires need to be connected to the proper side of the receptacle.
The black connects to the gold screw on the shorter slot side of the receptacle.
The white connects to the silver screw on the longer slot side of the receptacle.
