Wiring a central air condensor
This is a new unit by York model number YCJD18S41S1A. Can't find service manual. However sticker says Max circuit breaker - 15. My plan is to us a 2 pole 15 amp breaker with 12/3 wire to a 15 amp fused outdoor service disconnect and a liquidtite or sealtite whip to the unit. My questions are. Can I use a 30 amp disconnect? Also I've been looking online and I can only
Find a sealtite whip with 10/3 wires in it. Is it okay to use the larger wire for the whip. I want to order parts online and don't want to have to send them back. Any help would be greatly appreciated. Frank
Ps: if anyone has the service manual for that model or knows where I can find it online in PDF format could you please either send it to me or tell me how to get it. Last resort I'll call York.
I can only find a sealtite whip with 10/3 wires in it. Is it okay to use the larger wire for the whip.
You are correct..... your unit requires 15A @ 240v. You only need two conductors and a ground. You also only need a non-fused disconnect.
Using the link below you can locate any manual you need for your unit.
InformationCenter/York/Archive_CDs/York_2010A/catalog/DETAILS/brand=york&id=2760.html
(Installation instructions would be akin to a service manual.)
