Wiring Help
Old 04-27-14, 07:13 PM
Wiring Help
Your help is much appreciated. I don't have much electric knowledge. I was moving some TV wiring around a junction box and noticed one copper wire showing. I am not sure if I bumped something and knocked something loose.
Don't think I did.
In this picture below it is the copper wire that is exposed to the left outside the junction box. Should I be concerned? Does it look like something that should be connected?
http://1drv.ms/1lYeTMx
Thank you.
Old 04-27-14, 07:20 PM
Received 3,898 Upvotes on 3,494 Posts
Yes.... that is a type NM cable (romex) and the white sheath needs to be at least 1/2" inside the plastic box. Then after the box is fastened the romex should be fastened/stapled within 6" of the box. That bare copper wire is the ground wire and needs to be attached to any other bare cables entering that box as well as to the receptacle, if installed.
Old 04-27-14, 07:25 PM
PJ Max thank you for you help. I'll need to hire someone that knows what they are doing.
Thank you again!
Old 04-27-14, 07:39 PM
The cable needs to be stapled within 8 inches of where it enters the box.
