Pull Disconnect Box
Old 04-30-14, 07:08 AM
C
Pull Disconnect Box
Hello. I'm wiring a 60 amp pull disconnect box for an air conditioning unit. I understand what "line and load" are but I'm not 100% sure I understand the wiring diagram for the box (see pic).
I have the standard 10-2 three wire setup with a black/white/ground.
I know the line and load ground wires go to the middle ground bar in the box (5 and 6 below). Looking at the diagram, I'm not sure where to put the line and load black and white wires.
_______
12 34
56
_______
1 and 2 are line and load on the left side of the box
3 and 4 are load and line on the right side of the box
5 and 6 are ground (center)
I want to be 100% sure so that I can complete the wiring. Thanks.
Old 04-30-14, 07:53 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Using your numbering system, 1 & 4 are LINE and 2 & 3 are LOAD.
Old 04-30-14, 08:05 AM
C
Thanks. I was hung up on wire color when all I really needed was to ensure line wires are connected to line terminals (load to load, ground to ground). Thanks.
