neutral buss termination question
Old 05-01-14, 12:35 PM
C
Looking closely at my neutral buss I can see where some of the neutrals were removed at some point for troubleshooting I presume and then retightened. You can see the indentation where the screw terminal used to compress the wire. The installer did not restrip the wires when reinserting....
Is this an issue I should address by restriping and reterminating all those connections?
Old 05-01-14, 01:10 PM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
I wouldn't worry about it as long as the neutral conductor wasn't broken.
