neutral buss termination question
Looking closely at my neutral buss I can see where some of the neutrals were removed at some point for troubleshooting I presume and then retightened. You can see the indentation where the screw terminal used to compress the wire. The installer did not restrip the wires when reinserting....
Is this an issue I should address by restriping and reterminating all those connections?
