Add new switch and light to the end of a 3 way switch
Old 05-03-14, 10:45 AM
R
Post Add new switch and light to the end of a 3 way switch
We have 14/2 going into a 3 way switch, then 14/3 going into a light fixture, then 14/3 continuing to another 3 way switch. That is the end of the circuit. I need to add a single switch to a light fixture at the end of this circuit. Is this possible?
Old 05-03-14, 10:49 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
Probably not. There is most likely not a neutral at the last switch but the hot and two travelers. Sounds like a dead-end three way.
Old 05-05-14, 03:59 PM
B
Adding fix at end of three-way
Removed original drawing that was too small. Drawings shows how to use X10 to add your light fixture if you are willing to use that product for your existing switching. You would need a two gang box at the far 3-way unless that new switch is in a different location.
Old 05-05-14, 06:04 PM
B
Add fix at end of 3way
Original drawing was not large enough. Ray thanks for enlarging. I did this one as print is clearer. Hopefully this one comes out the right size.
Name:  X10 Wiring Fix.jpg
