subpanel
Old 05-04-14, 07:40 PM
C
subpanel
I have 1 subpanel from 60 amp breaker in main 200 amp breaker box.
can I add another subpanel to my work shop using a 60 amp breaker with
6-3 with ground wire.
Old 05-04-14, 08:05 PM
ray2047's Avatar
Do you mean a subpanel from the subpanel? Yes if it has the capacity. What are the loads on the first subpanel? What are the anticipated loads on the new subpanel?
Old 05-04-14, 08:47 PM
C
subpanel
want to run 2 subpanel from 200 amp main breaker box
first one has 60 amp breaker
Old 05-04-14, 09:06 PM
C
using 2 60 amp breaker
Old 05-04-14, 09:24 PM
ray2047's Avatar
Shouldn't be a problem. Have you done a load calc on the main panel. Is your home all electric including electric heat?
Old 05-04-14, 09:31 PM
C
no electric heat just a/c on 30 amp breaker
Old 05-05-14, 05:01 AM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
Shouldn't be a problem. .................
