Exahust fan question
Old 05-05-14, 03:09 PM
Question Exahust fan question
This is a odd one.. two switches one for the light and one for the fan, the light seems to be tied into the fan switch but when I opened up the box you had a white wire just hanging in the box with electrical tape over the end, the fan has no power, from the measurements I took on the switch closest to the camera, the top black to box is 120V and the other is 0V
I'm not sure what's going on
Last edited by ray2047; 05-05-14 at 04:45 PM. Reason: Remove Tinypic linkks and insert image.
Old 05-05-14, 03:18 PM
Welcome to the forums.
That is actually wired to new code which requires a neutral at every switch location.... whether used or not. In your case.... the neutral was not needed.
At that box you have one black wire that should have 120vac on it and it's connected to one side of each switch. The two taped black wires are the switched lines to the appliance.
Have you measured any 120vac at this box ?
Old 05-05-14, 03:22 PM
I have 120V at the switch, the light is connected to the switch that should be powering the fan, when I flip the switch to the fan I get nothing at all..
Old 05-05-14, 03:48 PM
Did you check for 120vac on both sides of the switch when it's turned on ?
Check to that white wire in the box. It is very likely that you have your 120v but are missing the neutral.
Old 05-05-14, 03:59 PM
Here is what happens when the switch is off the voltage is 86.7v when its on its 0v
Now that white wire to the hot To the white wire is 120v
Now if I turn the switch on and check the lower black wire to the white I get 120v with the switch on and 24v with the switch in the off position
Old 05-05-14, 04:04 PM
With the switch on.........
do you get 120v from each screw to the white wire ?
do you get 120v from each screw to the metal box ?
Old 05-05-14, 04:10 PM
yes and yes I get 120v with the switch on
Old 05-05-14, 04:14 PM
Then 120vac is not your problem. You have power entering and leaving the switches.
Now you need to go back to the fan and check voltage from the black to the white and from that black to ground.
