Running power to detached garage
Old 05-05-14, 06:58 PM
P
I was looking into running power out to my garage to install power for 2 garage door openers, 3 lights and 4 outlets for small items (TV, radio...). The run is 90 feet from panel inside house to garage. I was thinking 12-3 wire from 20 amp breakers buried 18" deep in grey pvc to junction box in garage with 2 GFIC outlets in the junction box. 1 for each circuit and then branch off from the load side of those. Does this sound ok or do I HAVE to go heavier wire and a sub-panel?
Old 05-05-14, 07:19 PM
ray2047's Avatar
12-3 would be cable. Best practice is to use individual (THWN) wire in conduit because it is easier to pull. A mutiwire circuit should give you plenty of power without needing a sub panel. You will need a disconnect at the garage. Either a DPST 20 amp switch or an unfused A/C disconnect. At the main panel you will need either two handle tied single pole breakers or a 2-pole breaker.
Old 05-05-14, 07:24 PM
Tolyn Ironhand's Avatar
Received 868 Upvotes on 731 Posts
You can use cable if you want, (as Ray said, not recommended) but if you do it needs to be UF.
Old 05-05-14, 07:56 PM
P
Old 05-05-14, 08:04 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
That one would work fine, but this one would also work just as well for half the price.
Shop Eaton 60-Amp Non-Fusible Metallic Disconnect at Lowes.com
Old 05-09-14, 02:31 PM
As was said you need to use UF if you're going to bury it. NM is not rated for exterior use and is not allowed to be run in a conduit unless only for protection from physical damage. Either use the THWN in a conduit to a sub-panel (my recommendation) or bury the UF straight to the garage.
Old 05-09-14, 07:11 PM
CasualJoe's Avatar
Although the NEC does not prohibit running NM cable in conduit, it isn't a good practice and would be hard to pull any distance and around bends.
