GFIC Receptacle problem
Old 05-06-14, 06:31 PM
T
I have three receptacles that are on one GFIC receptacle. These three receptacles do not have power and the reset button on the GFIC Receptacle will not reset when I press the button. But, when I plug something into the GFIC receptacle, it has power.
Thank you in advance for any help or advice.
Old 05-06-14, 06:34 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
The GFCI device is either wired incorrectly or is faulty and needs to be replaced.
Old 05-06-14, 06:47 PM
Received 3,976 Upvotes on 3,569 Posts
Welcome to the forums.
That sure sounds like the line and loads were incorrectly connected backwards to the receptacle.
Old 05-06-14, 07:21 PM
T
This GFIC has not been replaced in several years, it was working fine until a couple days ago. I will try replacing the GFIC receptacle.
Thanks for your quick response!
