Reload this Page >
Can one unused 10 ga 240V line be split in to two 110v circuits (shared common)
Old 05-10-14, 09:52 AM
K
I'm converting a garage into a house. I don't need the 10/3 240 line for my electric heaters any more, but I DO need more 110 V cirtuit lines. Can I use the two hots from the 10/3 cable to create 2 110V hot leads AND CAN THEY BOTH USE THE ONE COMMON WIRE ?
I'm not at the box/panel, I want to use the line on the other side of the house. Everything is insulated and I don't have to run new cable all the way from the box.
Old 05-10-14, 11:41 AM
ray2047's Avatar
No but you can create two 120 volt multiwire circuits with a common neutral. The breaker could not exceed 20 amps and must be either two handle tied single pole breakers or 2-pole. If the garage is detached this is the only power source that can be run to the garage and it wouldn't meet minimum code requirements for a house.
Old 05-10-14, 03:01 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
You probhably need 50 or 60 amps minimum for cooking/heating a one or two room space converted from the garage (assumed attached garage), the 10-3 won't be much good for your needs.
I don't know why anyone would run 10-3 to electric heaters. I suspect you have 10-2/G and not 10-3.
Old 05-10-14, 03:12 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
A house is going to require a 100 amp minimum service per code.
Old 05-11-14, 08:45 AM
K
clarification
your right, it's only 10/2 wire. I certainly don't have the opportunity to make it into 2 circuits.
Old 05-12-14, 07:28 AM
CasualJoe's Avatar
So.....is the garage attached to the house or is it detached?
