wiring / light
Old 05-11-14, 01:35 PM
T
Received 3 Upvotes on 3 Posts
wiring / light
Can i wire a 3 bulb halogen light, that uses the gr10 bulbs 50 watt(two round twist in contacts at bottom)in on a 15 amp switch loop light circuit ,with out any issues? the light before it is on the dimmer but i dont think that will be a problem.
Any info is appreciated
Old 05-11-14, 01:47 PM
Received 3,422 Upvotes on 3,068 Posts
You are removing one light fixture and replacing it with a new 150 watt three bulb unit.
I don't see any problems with that replacement.
