Adapter for old air conditioner plug
Old 05-12-14, 07:26 PM
Question Adapter for old air conditioner plug
I live in an old Victorian home with an old White Westinghouse air conditioner "built into" the window. The cord has an odd plug on the end, it has 2 flat pins in a v shape and a third flat pin. From what I've read it looks like a Type I plug used in Australia, but I'm not positive. The one outlet that it fits into shorted out because water from a leak in the ceiling got into it and it blew out. Is there an adapter I can use to insert the plug into a standard US outlet?
Old 05-12-14, 08:22 PM
F
Your description sounds like NEMA 10-20P. does it match any of these images?
http://www.buildmyowncabin.com/elect...eceptacles.gif
What does the nameplate say about voltage and amperage or watts?
Old 05-12-14, 08:55 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
Adapters are not commonly made as the equipment has specific voltage and ampacity requirements that the adapter would not compensate for.
