Help wiring
Old 05-12-14, 08:46 PM
4
Help wiring
Hello everyone I installed a sub panel in my workshop along with lights and fans I need wiring them I have 1/2 conduit going From the subpanel to the switch location then I have another 1/2 conduit stubbing up to a J box their I have a 90 going down to outlet and another one going to the first fixture then to a can and to another fixture then to the last fan , I plan on having the outlet on a 20 amp breaker and having the lights and fans on a 15 amp breaker here's a picture thanks[ATTACH=CONFIG]31595[/ATTACH]
Old 05-12-14, 09:37 PM
ray2047's Avatar
What are your questions? I don't see them in your post.
Old 05-13-14, 06:28 PM
4
Which way should I wire the fixtures and fans
Old 05-13-14, 06:43 PM
ray2047's Avatar
Use THHN #14 for the lights and #12 THHN for the receptacles. You can run both in the same conduit. Many electricians would also suggest running a ground wire even though the conduit serves that purpose also. When you run two circuits in the same conduit you can use one ground wire for both circuits. The ground wire is sized to the higher amperage circuit so in conduits that have both circuits use #12. In #14 only runs #14 ground.
Old 05-14-14, 06:17 AM
4
So I would run two white two black and one green....
Old 05-14-14, 08:40 AM
ray2047's Avatar
Yes, with the green sized to the highest amp circuit. At each junction box the green must be pigtailed to the junction box.
Old 05-14-14, 07:27 PM
4
Ok thanks. And to wire the switch To the lights and fans I just connect The blacks to blacks whites to whites and ground to switch box/ junction box / fixture correct
