Cable run problem
Cable run problem
Hi all, I'm in the process of remodeling my 2nd floor of my home. No doubt many of you veteran electricians must have come across the building techniques used when a home was built in the 1800's. My plan is to install a 3 way switch at the bottom and top of the stair way. The problem I have is the 2x4's they used were never installed the way they are today; Today you have a 4 inch deep wall (okay closer to 3 and 1/2 inch deep). Back when this house was built, the 2x4's were installed in such a way that the wall is only 2 inches thick. Can I use MC 12-2/G cable or is there a better/cheaper way to do this? Thanks, Roger
You just need to keep the cable at least 1 1/4 inch from the side of the studs. Something like a Colorado Jim would work to secure the cable. You will need to use metal boxes with plaster rings since the wall is so shallow.
Another question regarding the Colorado Jim (I Googled it and I can see how it would work my situation). Can NM-b, coax and Cat6 EtherNet cable be in the same bracket? Or do they need to be in separate brackets? Roger
