Is two switched hots in one conduit code compliant?
Old 05-15-14, 05:41 AM
D
Received 1 Upvote on 1 Post
I currently have the following setup:
- two outlets in the ceiling
- one outlet with the light switch
- metal conduit from the light switch to outlet #1, conduit from outlet #1 to outlet #2.
Currently there is one switch for both outlets as there is only one hot wire going into the ceiling.
I would like to have a switch for each outlet. Therefore I would like to pull a second hot into the conduit.
Is this code compliant?
Old 05-15-14, 06:29 AM
ray2047's Avatar
Yes, that is code compliant.
Old 05-15-14, 04:43 PM
D
Thanks.
What is the best method to pull that second wire? Attach two new wires to the existing hot and pull out the old wire?
Old 05-15-14, 04:59 PM
pcboss's Avatar
Received 192 Upvotes on 168 Posts
A fish tape could be used to pull the extra conductors or you might be able to push them through.
