Submersible Pump Cable
Old 05-15-14, 08:03 PM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
My friend's parents got a new well pump and they gave me the wire. It's about 200' of finely stranded 14/3 with a super flexible rubber insulation similar to heater cord or SJO cable. What strikes me as odd, however, is there is no ground wire, just a red, yellow (probably was once white) and black. Is there any way I can legally make this an extension cord? I was thinking either using 5-15 plugs and using the yellow as ground, red as hot, and black as neutral. Or another thing I have is L10-20 connectors which I could run 2 15A circuits through and put on some 2-prong female connectors. Any suggestions? It seems real nice for Christmas lights....
Old 05-15-14, 08:40 PM
F
...yellow (probably was once white)...
Nope, it has always been yellow.
I know almost nothing about submersible well pumps or their installation but I do know that 3-conductor cable is the norm. No, no equipment grounding conductor either. That cable runs from the pump motor to a control box that has a starting capacitor and a starting relay. The yellow conductor is for the starting winding on the motor through the capacitor and relay.
Technically, no you cannot use it for a 120 volt extension cord because the insulation colors are wrong. But, if you don't tell anyone...neither will I.
Old 05-15-14, 08:52 PM
There is a 4-conductor variation that also includes the green. But it still has the red/yellow/black, no white. The flat jacketing is odd though.. Normally the conductors are just twisted around each other with no outer jacket.
Old 05-16-14, 05:22 AM
P
Received 1,764 Upvotes on 1,577 Posts
If it were #10 wire or maybe even #12 I'd consider making a 200' extension cord but #14 is not all that special and rather small for a really long extension cord... unless you happen to need a really long extension cord.
Old 05-16-14, 02:51 PM
I think the yellow is going to be white.
I have several hundred feet of the 4-conductor #10 at my land. The yellow became white and is used to connect the generators to the sub panels. The cable I have pictured is from a house built about 40 years ago.
If I use this for incandescent lights, voltage drop will only make them last longer.
Old 05-16-14, 06:18 PM
Received 3,420 Upvotes on 3,066 Posts
Stranded.... huh. Most of the wiring for wells is solid.
Old 05-16-14, 10:29 PM
This is pretty interesting stuff, that's why I don't want to waste it. What amazes me is how there can be splices on the pump 600 feet down and they don't get filled with water.
Old 05-16-14, 11:07 PM
I imagine they use splices similar to what you use for UF or USE.. The ones with the glue-filled heat shrink that makes the splice waterproof.
