branching vs chaining outlets
Old 05-15-14, 08:55 PM
D
I need to run 3 outlets in my unfinished basement, I will tap into an existing line with only one outlet on it and run towards my intended direction. The layout plan is in the form of a "T" so it will be more practical to BRANCH rather than CHAIN the outlets. Is it acceptable to run the power wire to a junction box and pigtail all the wires (4 wire pigtail) and than run the 3 branch lines out from there?
thank you
Old 05-15-14, 09:00 PM
F
Received 39 Upvotes on 31 Posts
NO! Absolutely not! Never!
Okay, I lied, what you propose is perfectly fine.
Old 05-15-14, 09:09 PM
A
Received 92 Upvotes on 84 Posts
With daisy-chaining you don't have as many issues with box fill. Branching out (hub-and-spoke) methods usually overload a standard switch/receptacle box. If your junction box is a 1900 (4x4) you should be good, though.
Old 05-15-14, 09:11 PM
D
you made me nervous for a moment!
i ask because adhering to a traditional "chaining" pattern will be a waste of unnecessary wire given the layout
thanks
Old 05-15-14, 09:31 PM
A
Received 285 Upvotes on 260 Posts
Example of box fill (U.S.):
One 12/2 power cable and three (12/2) branches continuing: 8 conductors equals 8 points. One receptacle unit (duplex or round single) in the box, 2 points. All the ground wires (equipment grounding conductors) 1 point. Any or all the cable clamps or fingers protruding into the box, 1 point. Pigtails (short lengths wholly within the box) e.g. to reach the receptacle, 0 points each. Wire nuts, 0 points each. Total of 12 points, 2-1/4 cubic inches per point equals a minimum box size of 27 ci.
Old 05-16-14, 08:01 PM
D
so a 4"x4"x2.25" square box = 36ci correct?
my junction box would be stand alone, hub plus 3 spokes (4 wire pigtail)
incidentally what is the maximum number of advisable wires in a pigtail?
Old 05-16-14, 08:45 PM
pcboss's Avatar
Received 201 Upvotes on 176 Posts
The pigtaoils are limited by the size of the wire nut and wire sizes.
