bathroom fan unit installation
Old 05-17-14, 05:31 AM
I am installing a new bathroom fan unit on a 3 rocker switch. It has a light, fan and heat. There is another light in the bathroom above the sink. I would like to connect it in parallel with the fan unit on a separate switch all off the same 120v source wire. Can this be done? and if so a quick explanation of the wiring would be helpful. Thanks
Old 05-17-14, 05:50 AM
I don't know what I was thinking. I am going to put the 3 rocker switch in series with the other light first and when the mirror light is turned on the rocker switch will be able to be used.
Old 05-17-14, 05:59 AM
pcboss's Avatar
Received 195 Upvotes on 171 Posts
The fan unit with heat is going to call for a new circuit due to the heat load.
