Connecting light switches to one source of power, pigtails?
Received 0 Votes
So I am installing over some old work, the old box was damaged and had to be removed.
I installed a 3 gang old work box, and it fits in nicely. I didn't record which wires went where, I have a general idea.
In that picture there is one source of power that all the wires need to be hooked to.
My question is do I need to create a pigtail, if so do I connect one specific wire, or do I do it for all three? Basically I am just asking what to do in this scenario, where there is one source and many others that need to connect to it?
You're talking about one hot wire being connected to all three switches.
Yes.... take three short pieces of wire and connect them to the hot line coming in. Push splice in back of box and leave the three tails coming out at the three switch locations.
Makes for a neater connection method.
Received 0 Votes
@casualjoe this is a project that was put off for a while and I forgot how it was previously wired.
@PJmax sounds good, but could you paint a better picture? Great answer but when I get back to it tomorrow I would like to know exactly what to do.
"leave the three tails coming out at the three switch locations."
I am not 100% clear on that. So on the hot wire, there is a black, white, and all copper wire. On the other wire sets for the switches they are black, white, and red? This is a bit confusing (mainly because of the red).
Now to your quote above, I assume the "switch locations" are the wire "set" for that specific switch (set of red,black,white). So you're saying leave three tails, one for each color (red[tail],black[tail],white[tail])? That would be a lot of wires, I couldn't fit that in there I don't think. Unless you mean each "set" should have its own tail (red,black,white[tail]?), if that's the case which wire should the tail come out of?
Basically I just need to visualize it better, I really appreciate the initial answer you've already done more that you had to, but painting a better picture would really ensure I get the job done much more smoothly!
You originally asked about the hot wire and pigtailing. Now you're asking how to wire the entire thing. You've got a two wire cable in there and 3) three wire cables and a piece of #12 NM in your hand.
Without knowing what the switches control and if they are single pole or three way.... we would be guessing in connecting them.
And to be clear my diagram was about pigtailing. Your picture of the box is undecipherable. Please post a picture of the box with the wiring fully displayed and labeled.
